Under-cabinet lighting
You need special downlights for cupboards - you can't simply using the ceiling ones.
So there are two layers On the bottom of your overheads, one standard and another to cover the light fittings, right?
Any chance of seeing a night pic of your lights on?
Thanks for thAt sc!
if the lights are not fitted inside as the above you should consider lights with built in transformers such as the Ikea ones yet they need source of electricity which comes from a powerpoint if you hate running cables under your cupboard then should get an electrician to chase the wall under the cabinets (however if you have an existing splashback then it is not possible unless you want to break and replace it)and drill through the cabinet to install a box powerpoint
Grinder, what lights/method do you recommend for brand new kitchens (if that makes any difference)?
blueblueblue
Any typ eof lighting and there a lots of them that can be plugged into a powerpoint inside the cupboard they either be externally mounted or internally mounted although internally mounted need to have good insulation as the surroundings inside the cupboard gets too hot. Besides if anyone has downlights switched for more than 10 minutes then that person should consider changing the lighting system in the kitchen.
Thanks for that grinder. Does the same Apply if I use cfl or LED lamps?
I thought LEDs were cooler temperature wise then halogen but i dont know anywhere i can find slimline LED lights for this purpose.. Maybe my sparkie can help
Hmm im in the middle of making the same decision. We want to have 4 built into our overhead cupboards
Try Ikea.com.au/lighting. I was looking at them yesterday.
I suggest using a search engine to search on LED strip light. There are ultrathin products available from within Australia and overseas. You can buy components and clip them together. See this post, and despite its title, follow the posts by zx9 and how he/she changed from looking for under cabinet fluoros to buying and install LEDs. This post also has examples and photos.
I got one of the following for each shelf. these seem to be plenty bright enough for a 1.5 meter wide pantry and are using less than 200 milliwatts each strip.
http://www.dealextreme.com/p/smd-12-led ... -12v-10293
and also the following for power.
http://www.dealextreme.com/p/ac-to-dc-1 ... 240v-15992
http://www.dealextreme.com/details.dx/sku.15992
The plan is to add in a circuit that switches it off if the door is not closed within 5 minutes so will make up a circuit for that myself, but there should be some off the shelf timers around.
1
1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it…
15/01/2024
I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to…
