Browse Forums Kitchen Corner 1 Jan 07, 2011 3:24 pm I need some advice. Our kitchen is being re-used from the exisiting part of the house, so we dont have much choice on the layout. The new kitchen area is narrower than the exisiting. Its a U shaped design, fairly standard with fridge on left wall, oven/pantry on right wall, sink( double bowl with drainer to the right) in the middle however....there is a window directly above the sink area..excellant however...if we have the sink directly under if doesn't give enough space then to have the dishwasher on the right and then have a corner pantry next to that...so my question...would it look absolutely ridiculous having the sink 'off to one side' to allow for dishwasher and corner pantry to fit?? I'm sure i can put something on the right of the sink to as a focal point to distract from the 'off centered' sink... thoughts... and unfortunately we cant position the dishwasher anywhere else other than right beside the sink.. (holes cut etc..) Just completed DIPLOMA INTERIOR DESIGN!! http://www.thelittleshouse.blogspot.com Check out our progress thread... viewtopic.php?f=38&t=39954&p=596811#p596811 Re: Help- Kitchen prob... 2Jan 07, 2011 6:27 pm Are you getting a double sink? Could you just purchase the double sink with the drainer on the side to sit above the dishwasher so overall the sink still kinda looks central? Its sort of hard to picture without a pic. Re: Help- Kitchen prob... 3Jan 07, 2011 9:07 pm Heres a pic.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We've already got the sink..all the kitchen is existing from before our extension started..so we're reusing it all. Just completed DIPLOMA INTERIOR DESIGN!! http://www.thelittleshouse.blogspot.com Check out our progress thread... viewtopic.php?f=38&t=39954&p=596811#p596811 Re: Help- Kitchen prob... 4Jan 08, 2011 6:18 am The only way to push the sink to the left is to have a sink with less cut out (measure the distance between the two bowls and get a new sink 650mm cut out with drainer over dishwasher) so that will give space to the dishwasher cavity and the corner pantry to the right You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 15610 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6636 2 4687 |
