Browse Forums Kitchen Corner 1 Dec 30, 2010 6:08 pm Sorry if this has been asked before.. I cant seem to find a clear answer in the archives. I'm beginning to assemble and install a flatpack kitchen, and don't know if it's ok to install a laminate floating floor (like from Bunnings) before the cabinets. I dont really like the look of beading at the kickboards/floor join.. and would prefer to just lay the floor first and place the cabinets over the top. But will this cause problems re contaction.expansion? Can this crack the benchtop? The cabinets will sit on legs, which I believe helps buffer from any small shifting. Not sure though since I'm no expert.. and I keep getting a variety of mixed messages from different tradies. Any advice would be greatly appreciated Re: Kitchen cabinets on a floating floor?? 2Dec 30, 2010 10:07 pm And may I ask why you choose to put the fit the base cabinets on a cheap flooring like laminated flooring when and if water get to it will ruin the floor and then you'll have to replace the whole lot. Re: Kitchen cabinets on a floating floor?? 3Dec 31, 2010 3:17 pm That's a good point Grinder! I have a good solid parquetry floor but where we pulled out an old bench there is a hole in it. I've been contemplating putting in a floating floor over it but it never occurred to me the floating floor might let water in. I'd better get on with repairing the parquetry I guess. Seashell Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3075 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 424 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10079 |
