Browse Forums Kitchen Corner Re: Ikea down lighting under top cupboards onto bench 11Jan 11, 2011 11:08 pm Hi If you want to change the lights to LED you are better of buying the strip LED lights. Unfortunately they dont make LED globes for those fittings you pictured. Not only that, LED need a driver to run. The LED downlight globes have that built in hence why they are $40+ each. Plus the strip lighting is longer, costs less to run, changes colour, and take up less room so possibly hidden from view. Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31369 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3868 Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16659 |
