Browse Forums Kitchen Corner 1 Dec 15, 2010 6:51 pm Hi All Wanted advice please. We have an island bench that someone has suggested widening. We agree this would look great. Problem is in the island bench there are two supporting beams going to the cathedral style ceiling. If we widen the bench the guy giving the quote said we would have to use two pieces of stone and that we would see the join as it would have to accomodate the beams. Not too keen on this - anyone had the same issue? Re: Island Bench - having to use two pieces of stone 2Dec 16, 2010 7:36 am don't have this issue, but I'll try to get a pick of the bench from my out-laws house You can barely see the join unless you stand right over it. Perhaps if you get some pictures others could offer advice. I will be having a similar problem when we upgrade our kitchen bench as it 4.75mt long and longest stone slab we could find was 3.15mt Re: Island Bench - having to use two pieces of stone 3Dec 16, 2010 8:43 pm We have a join in our bench - it really bothered me in the beginning, esp as I was never told there would be a join (and being a naive 1st time builder didn't realise or even think about the maximum lengths of stone) - now however I don't even notice it - it helps though that they put it in the least obvious place - am thankful of that at least!!! Building on the Sunshine Coast - Land settled 22nd July 2009 Building contract finally signed (after much deliberation on our part) 11th November 2009 Building commences 25th January 2010 - small local builder End of June - almost completed fit out 26th July - MOVE IN DAY!!!!!!!!!!!!!! Re: Island Bench - having to use two pieces of stone 4Dec 17, 2010 11:28 pm Our Caesarstone benchtops have a corner join that blends into the stone. It's there if you look but most of the time you don't even notice it. We also considered Staron® Solid Surfaces which could possibly be installed in your situation without any visible seams. Re: Island Bench - having to use two pieces of stone 5Dec 19, 2010 11:14 am We have two joins in our benchtops due to angles, and while they're not invisible, if you didn't know they were there, you wouldn't notice them. Re: Island Bench - having to use two pieces of stone 6Dec 19, 2010 1:44 pm We also have one join in our stone that I'm aware of but i don't notice it unless I actually look for it. traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4203 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6580 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 20893 |
