Browse Forums Kitchen Corner 1 Dec 10, 2010 9:41 pm I'm looking for something durable for my kitchen cabinet. Any advice on whether colorform or polyurethane is better. They both seem to have similar gloss but not sure which one can be cleaned easily, esp oil stains after some heavy cooking. brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7587 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1457 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3077 |
