Hi all
My question is whether there is a state or any other regulation stating cabinet heights apart from rangehood distance between gas burners and cooktops?
Thank you
Browse Forums Kitchen Corner Re: Overhead cabinet heights? 2Dec 08, 2010 10:06 am AS/NZS 4386.1:1996 states that...In no case shall the clearance between the top of the highest burner on the cooker and a rangehood or exhaust fan be less than 600mm. Any other combustible materials less than 600mm above the top of the highest burner shall be protected for the full width and depth of the cooking surface area however, in no case shall this clearance be less than 450mm. AS/NZS 4386.2:1996 states that...The minimum vertical distance between cooktop elements or gas burners and a combustible material shall be 600mm. This clearance applies to the whole cooktop area. AS/NZS 4386.1:1996 6.2.1.3 Splashback zone The clear vertical space between wall units and the worktop shall be at least 450 mm; the clear vertical space between cooking area and range hood or overhead wall unit shall be as required by the relevant statutory authority. Cheers, Earl Re: Overhead cabinet heights? 3Dec 08, 2010 3:48 pm Thanks Earl but this are only suggested standards not in force. I have made investigations and Commonwealth and state levels and nothing found even Archicentre has not been able to respond no mandatory legislation regarding the clearance beyond cooktop area by State Building Admin in Victoria for instance not even the building code suggests any height beyond cooktop are. So if one desires to have more than 450 beyond cooktop the it should be assume it an option to set the cabinets at this height so far as the rangehood clearance is in place for the right type of hob. Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16615 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1337 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 12001 |
