Browse Forums Kitchen Corner 1 Nov 29, 2010 8:03 am I'm after someone to make up and install stainless steel bench for a domestic kitchen. Can anyone recommend someone reasonably priced in southwest Sydney. Thanks Peter Re: Stainless Steel Benches? 2Dec 07, 2010 7:02 am Steel manufacturers do make benches and kickboards from those steel coils or rolls either from the steel miils or imported they cost just about the same money as aggregate stone benches to give you an idea one advantage though is they are normally seamless they fold neatly at the edges so there is no grooves to hide or dirt, grime and bacteria to grow and there is no problem bashing the cookware against it nor it cracks. I have chosen the stone as benchtop simply because of price considerations however I was also looking at steel but the cost was just about the same as we do tend to use the surface quite a lot. Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6740 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14458 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7035 |
