Browse Forums Kitchen Corner 1 Nov 14, 2010 7:05 pm Hi, This is my first time posting and I am so pleased to have found this site. I am building a house on my own for myself and my two young boys and look forward to being able to get advice and opinions. I have recently been in a DA display home and liked the way they added some extra storage to their island bench. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Do you think something like this would work for my kitchen? I was thinking a bit shorter and narrower. Or does anyone have any other suggestions? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am lucky that my dad is building my house and I can make changes like these as we go. Thanks for looking, SannieB Re: Please help with island bench ideas. 2Nov 15, 2010 8:53 am I don't see why not, Sanni. i can't quite make it out on my screen, but is it already on the plan at the opposite end from the sink? The only thing I would say is that it doesn't look like you have a lot of room as a walkway on either side of the island. If you did it. I would take a little room off the bench space so it's still about the same length as the bench behind. Re: Please help with island bench ideas. 3Nov 15, 2010 10:23 am Depends where you are putting it? We have pretty much the exact setup but ours is on the front of our island bench (forms the splashback for our sink). If you placed it on either end of your island it may impact on your walk through. IMO you always need to allow for 1.5m between the island and any adjoining walls - to allow for traffic / moving large items in and out of the room. Some things are worth waiting for. Re: Please help with island bench ideas. 4Nov 23, 2010 12:03 am You don't have enough room to do it at the sides. How long is your island bench? If you had enough space you could centralise the sink and as Kyton has done, use it as a splashback. Looking at the small size of the plans though I'm not sure it would leave you enough prep size either side of your kitchen. If it is storage you are after, why not thicken the island itself and you can have hidden cupboards under the overhang/waterfall. How thick is the island? Our current plan has a 1.2m thick island (although i'm currently consulating with a kitchen designer). DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6584 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11683 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31263 |
