Browse Forums Kitchen Corner 1 Oct 31, 2010 2:34 pm Can a 3 drawer unit (flatpak) be installed next to a solid fixed wall? Or do you have to install an end panel. Thanks Re: Help Kitchen Plan Question 2Oct 31, 2010 5:09 pm A drawer unit CAN be installed right up next to a wall but it is highly recommended to fit an in-fill panel between the cabinet and the wall. Main reason for this is that if the wall runs in at all then the drawers might end up fouling on it (and I have never seen a perfectly straight wall, even on new builds). Drawer fronts themselves are normally 1.5mm to 2mm narrower than the carcass on each side so if the cabinet gable and the wall are perfectly parallel you might just get away with it; but this narrow clearance is also a finger trap/pinch hazard and can cause quite a bit of pain so if you can mange to squeeze an infill in I would. Cheers, Earl You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9971 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11258 we need accurate dimensions as well as the number of bedrooms and bathrooms needed etc to make specific suggestions but, based on estimated rooms sizes, it could be… 1 579 |
