Browse Forums Kitchen Corner Re: ******* kitchen by PD access - damaged 8Oct 27, 2010 9:52 am Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: ******* kitchen by PD access - damaged 10Oct 28, 2010 2:21 pm I suggest this will have to be a repair job and not a replacement. Is that an engineered stone for your bench top? If so this will be (or should be) laid over a substrate which will be attached to the actual cupboard frames below. The engineered stone will be glued/siliconed to the substrate. Removing both of these will be nigh on impossible other than just about wrecking the top and the substrate - this they are unlikely to do. But it must at least be repaired as that edge that is missing along the front of the sink will be what your cupboard doors will rest against/close onto. Not a good job otherwise. Good luck with it. barkly It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2213 For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9094 |
