Browse Forums Kitchen Corner 1 Oct 17, 2010 8:35 am Seems to be no specific area for laundry, mods, feel free to move if this is not the best area a couple of pics, basically before & after, of our laundry Stripped the room back to ceiling joists, wall studs & floor joists Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wife & I did the work (including the bulkheads), cost was approx $4,500, took about 2 weeks to do (plus 4 weeks waiting for the bench top!) the tall cupboard is a drying cupboard, ducted heating vent providing the necessary heat & air flow to dry the clothes SWMBO is happy with her new laundry Re: Laundry reno 2Oct 17, 2010 8:58 am We also use the ducted heating vent to dry clothes in our laundry but not in a cupboard. That's a good idea nice and tidy!! I assume the door is vented at the top? You've done a nice job, I would have preferred a larger trough/sink as I often wash bulky items in there like rangehood trays big vases etc. I rarely hand wash anything though Re: Laundry reno 3Oct 17, 2010 9:02 am Looks great Is the drying cupboard something you put together yourself? Would you have a link to more info? Our veggie bed thread: viewtopic.php?f=19&t=38476 Re: Laundry reno 4Oct 17, 2010 9:31 am Trish We also use the ducted heating vent to dry clothes in our laundry but not in a cupboard. That's a good idea nice and tidy!! I assume the door is vented at the top? not the door(s), vented through the ceiling, yet to be hooked up to outside though. Quote: You've done a nice job, I would have preferred a larger trough/sink as I often wash bulky items in there like rangehood trays big vases etc. I rarely hand wash anything though the sink is 430mm diameter, about 250 deep, the tap head is extendable by about a meter Re: Laundry reno 5Oct 17, 2010 9:40 am lonnie Looks great Is the drying cupboard something you put together yourself? Would you have a link to more info? It started life as a standard 900mm wide pantry cupboard, bought from Bunnings. When we had the new ducted system put in we had a vent added to the laundry, basically we just cut a matching hole in the cupboard floor and extended the vent up. We then bought a couple of metal clothes horses and 'redesigned' their use http://picasaweb.google.com/lh/photo/Av ... directlink the whole thing, from go to whoa: http://picasaweb.google.com/TerrianC/Laundry# Re: Laundry reno 8Oct 17, 2010 10:23 am Quote: the tall cupboard is a drying cupboard, ducted heating vent providing the necessary heat & air flow to dry the clothes If you do not have any damp clothes in this cupboard to dry can you shut off the hot air flow? (And if you can - do you remember to do it?) Otherwise you will be pumping warm air into your roof cavity and so lead to higher heating costs. barkly Re: Laundry reno 9Oct 17, 2010 12:20 pm barkly Quote: the tall cupboard is a drying cupboard, ducted heating vent providing the necessary heat & air flow to dry the clothes If you do not have any damp clothes in this cupboard to dry can you shut off the hot air flow? (And if you can - do you remember to do it?) Otherwise you will be pumping warm air into your roof cavity and so lead to higher heating costs. barkly SWMBO closes the floor vent when clothes are not in there, the floor vent is a standard ducted heating floor vent I am working on a 'valve' so the air can be directed to either into the cupboard or into the laundry from under the cupboard. Re: Laundry reno 10Oct 17, 2010 12:43 pm Terrian It started life as a standard 900mm wide pantry cupboard, bought from Bunnings. When we had the new ducted system put in we had a vent added to the laundry, basically we just cut a matching hole in the cupboard floor and extended the vent up. We then bought a couple of metal clothes horses and 'redesigned' their use http://picasaweb.google.com/lh/photo/Av ... directlink the whole thing, from go to whoa: http://picasaweb.google.com/TerrianC/Laundry# Great to see all the photos! Thanks for that info, too. Our veggie bed thread: viewtopic.php?f=19&t=38476 Re: Laundry reno 11Oct 17, 2010 12:55 pm Terrian barkly Quote: the tall cupboard is a drying cupboard, ducted heating vent providing the necessary heat & air flow to dry the clothes If you do not have any damp clothes in this cupboard to dry can you shut off the hot air flow? (And if you can - do you remember to do it?) Otherwise you will be pumping warm air into your roof cavity and so lead to higher heating costs. barkly SWMBO closes the floor vent when clothes are not in there, the floor vent is a standard ducted heating floor vent I am working on a 'valve' so the air can be directed to either into the cupboard or into the laundry from under the cupboard. I wonder if the laundry could take the air being directed back into the room at the top of the cupboard. I realise there would be moisture and therefore possibly mould..... Good luck with your valve! Re: Laundry reno 13Oct 17, 2010 1:27 pm Trish I wonder if the laundry could take the air being directed back into the room at the top of the cupboard. I realise there would be moisture and therefore possibly mould..... the GLW was adamant that the air coming from the drying cupboard not be returned to the laundry because of moisture (bear in mind the plaster was all primed with antimould primer, the paint is also antimould) Quote: Good luck with your valve! the theory is simple, the design is simple, the 'get off ya bum and do it' is the hard part ( http://picasaweb.google.com.au/TerrianC shows what we have been up to the last couple of years!) Re: Laundry reno 14Oct 17, 2010 1:28 pm I love your laundry! I have serious laundry envy. Congrats on a fantastic job. My house and my rants.... - viewtopic.php?f=31&t=26937 We are in!!!...and still unpacking. Thankfully there are always Tim Tams Re: Laundry reno 16Oct 17, 2010 1:48 pm We move into our current home 9 years ago. Our laundry is tiny, but has some room for a two door cupboard and OH cupboard. Have been asking for one 9 years, finally got one 6 weeks ago.....when the house went on the market So typical My house and my rants.... - viewtopic.php?f=31&t=26937 We are in!!!...and still unpacking. Thankfully there are always Tim Tams Re: Laundry reno 17Oct 17, 2010 1:59 pm mpcj We move into our current home 9 years ago. Our laundry is tiny, but has some room for a two door cupboard and OH cupboard. Have been asking for one 9 years, finally got one 6 weeks ago.....when the house went on the market So typical LOL Re: Laundry reno 18Oct 17, 2010 2:08 pm the theory is simple, the design is simple, the 'get off ya bum and do it' is the hard part ( http://picasaweb.google.com.au/TerrianC shows what we have been up to the last couple of years!)[/quote] So true! Not one room in my house is complete - hmm maybe our daughter's room is ... We only been at it for 30 years - so long now that it all needs redoing - hence why I like dreaming whilst looking at what others have done! Last time we repaired and painted our lounge room was during our honeymoon - we've been married for 31 years I did get a new window in there and that's actually finished as in stained glossed and architraved. Re: Laundry reno 19Oct 17, 2010 3:16 pm mpcj We move into our current home 9 years ago. Our laundry is tiny, but has some room for a two door cupboard and OH cupboard. Have been asking for one 9 years, finally got one 6 weeks ago.....when the house went on the market So typical ah well, at least you know how long some thing is going to take to get done Re: Laundry reno 20Oct 17, 2010 3:23 pm Trish So true! Not one room in my house is complete - hmm maybe our daughter's room is ... We only been at it for 30 years - so long now that it all needs redoing - hence why I like dreaming whilst looking at what others have done! Last time we repaired and painted our lounge room was during our honeymoon - we've been married for 31 years I did get a new window in there and that's actually finished as in stained glossed and architraved. all bedrooms, bathroom, laundry & toilet are complete, lounge/dining need some architrave work though, the kitchen, a workshop, 4m x 13m back verandah and & new room on the front are on the drawing board for us, the GLW says she hasn't learned patience, she has it it forced upon her Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10374 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8775 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17149 |
