Kitchen cabinetry colour - which white? Too many to choose!
This is the first time I've posted on this forum but I've been amazed how helpful you all are!
I'm trying to work out the colour for my kitchen cabinetry and need to decide by the end of the week. We want a 'white' but there are so many to choose from! Our cabinetry will be satin finish 2 pack poly finish and the style is shaker/boston. The bench tops are Organic White Caesar and the splashback will be glass in a mid grey to charcoal grey colour. The floor is timber boards.
The other colours in the room will be muted neutral colours but the wall colour will have a bit of depth to it.
I'm after a white that has no creamy/yellow tones, but is not too stark a white. I thought of something with grey undertones to pick up the grey in the splashback and the feint 'watermark/swirls' in the caesarstone, but I'm worried that it might look a bit cold (not warm enough).
I have had Dulux Lexicon, Whisper White and Natural White recommended to me but I would be very grateful for any other suggestions!
It seems a big decision as the kitchen is quite large and is the centrepiece of the main family/dining/outdoor entertaining area so I really want to get it right. Sorry this is a bit long winded - I thought having white it would be easy!
Many thanks
Emma
Of the ready made options, I would have said Lexicon was a good option.
But I would suggest you take your color scheme (benchtop, splashback and floor board) to your spray painter and get them to develop something. See what they can come up with. We did this and we were very happy with what they did (we wanted a very "steely" white).
Sorry for such a late reply but I only just came across your question, so although you have probably already settled on which white to go with, I thought I may as well give you my suggestion... just in case!
Dulux White Duck Qtr or Lexicon
If you have already decided, do you mind me asking which one you went with, as we are in a similar position at the moment. We originally went for the standard laminex cupboards for the kitchen, but then decided to upgrade to the laminex gloss vinyl wrap. When we going with the standard laminex we chose the colour "White 200" (just the standard white) but when we changed over to the gloss vinyl wrap the admin girl changed the colour to "polar white" which I believe is a very stark white. I don't know why they changed the actual colour, unless the "white" doesn't exist in the gloss vinyl wrap? But now that they have changed the paperwork to polar white I am worried it will look too stark. So if you could let me know how you went it would be very helpful.
Thanks.
We have Laminex White in 2 pak, as opposed to Polar White which, as you say, is very stark. My white is not cold at all, it's just right.
Hmm! Can you clarify a little more suh laminex is a standard generic name for which this material is known in the market however there are many more manufacturers and names that make similar "laminexes" white 2 pak means nothing unless there is a colour code or a proper name for which the fabricator and cabinet makers know as.
Thanks
I bought a sample of Lexicon today and painted it onto some cardboard. I thought it was going to be perfect but was a bit disappointed as it actually seemed too grey against the Caesar stone sample- well more grey than what I thought it would be. I might try it half strength and see what that looks like. I'm also going to check out the Dulux White Duck (thanks aldavies3!) and see if that might be a better match.
If I can't work it out after that, I think I'll give it the joinery maker (spray painter) and see what they can come up with. I think for $100 they can have it professionally matched by the paint company - which may end up being a good investment!
It shouldn't be this difficult! White is sooo much harder than I thought it would be!!!
Cheers E
Thanks
You learn something new every day
emma....I would suggest visiting a Laminex showroom and get some samples. Mine is called Laminex "White" as opposed to Laminex "Polar White" and other Laminex whites, once you put a few near each other it's much easier to see the differences and you may be able to match a paint colour to it.
Unless you wanted everything to be muted, ie. with similar tones, nothing standing out or highlighted
Thanks
I think 'Polar white' is the name of the LAMINEX (brand) that is from the LAMINEX Diamond Gloss range...LAMINEX Diamond Gloss have other whites too in the range like 'White Valencia'.... LAMINEX have other whites in their normal 'laminex' range too. . I think suh was talking about LAMINEX (the brand) in particular and these are the 'proper' names.
I don't think the "polar white" is specifically from the Laminex Diamond Gloss range, as it is also in the standard laminate range, the vinyl-wrap range, the diamond gloss range, and I think in many other of ranges of their products too. I have all their pamphlets, outlining all their differenct ranges, downloaded on my computer but I really can't be bothered reading through each of them right now!!!
Looking for advice on whether this variation in tile colour is acceptable. The large tile on the left was used in my main bathroom renovation 1 year ago. My ensuite…
26/04/2024
2
Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra…
14/12/2023
14
I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with…
