Browse Forums Kitchen Corner Re: Under Cupboard Downlights for Flat Pack Kitchen Cupboard 2Sep 30, 2010 7:05 pm It can be quite easily done in a number of ways - it sounds like you want to put lamps in the top of the cabinets providing internal illumination? There are quite a few lamp options that are specifically fabricated at 16mm thick; these can be set flush into the top board of the carcass, wires (and transformer if required) get run above the cabinet to the power source/switch - these can be simply left on top of the cabinet or concealed with a bulkhead or decorative trim. If you want to do a similar thing but with the lamps mounted in the base of the cabinet illuminating the benchtop you can get a melamine board cut to the internal dimensions of the base of the wall unit - again the lamps get flush mounted in the base board and the wires and hole can be covered with the second board; the frame from the door will conceal the second board when the doors are closed. Lots of lighting suppliers can help you with the lamps you are after; Haefle also have a very nice minimal LED lamp that I am particularly fond of but it is not the cheapest solution. Cheers, Earl That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 733 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3439 |
