Under Cupboard Downlights for Flat Pack Kitchen Cupboards
There are quite a few lamp options that are specifically fabricated at 16mm thick; these can be set flush into the top board of the carcass, wires (and transformer if required) get run above the cabinet to the power source/switch - these can be simply left on top of the cabinet or concealed with a bulkhead or decorative trim.
If you want to do a similar thing but with the lamps mounted in the base of the cabinet illuminating the benchtop you can get a melamine board cut to the internal dimensions of the base of the wall unit - again the lamps get flush mounted in the base board and the wires and hole can be covered with the second board; the frame from the door will conceal the second board when the doors are closed.
Lots of lighting suppliers can help you with the lamps you are after; Haefle also have a very nice minimal LED lamp that I am particularly fond of but it is not the cheapest solution.
Cheers,
Earl
3
Waterproofing wet areas, including laundries is a requirement now. I don't know if it was 12 years (for a laundry) but I can't see why it would t have been. Have you got…
26/04/2024
2
Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra…
26/06/2023
Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a…
