Browse Forums Kitchen Corner 1 Sep 03, 2010 12:26 pm I got told by my kitchen installer that splashback comes at the very end after everything is installed but I can't see how this is going to work with the splashback needing to sit behind the ranghood? This is what I had in mind http://www.rangehoodducting.com.au/imag ... 0glass.JPG Re: Installing glass splash back behind rangehood 2Sep 03, 2010 12:34 pm Your cabinet maker wont install the rangehood (not that type anyway), your electrician should So once the cabinets are in, in comes your splashback, and then your electrician/plumber Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Installing glass splash back behind rangehood 3Sep 03, 2010 12:40 pm Bam Your cabinet maker wont install the rangehood (not that type anyway), your electrician should So once the cabinets are in, in comes your splashback, and then your electrician/plumber I'm paying them to do the whole job though. The PM is gonna sub contract the electrician and plumbing required to remove and install all the appliances and the cabinets. Guess was hoping they'd do cabinets + appliances in one go but now looking at it they might have to do the cabinets first and then install the appliances on another day? ps: your girl looks very cute Re: Installing glass splash back behind rangehood 4Sep 03, 2010 2:12 pm The glass needs to have holes cut into it where the rangehood fixes to the wall before it is put through the hardening process; this is best done by hanging the rangehood where you want it then taking it off the wall so the splashback people can make a template of exactly how the (finished) piece of glass will look. Whoever hangs the rangehood needs to make sure they allow for the thickness of the glass going behind it if they cut any holes in the ceiling for ducting before the glass is up. Cheers, Earl Re: Installing glass splash back behind rangehood 5Sep 03, 2010 2:43 pm frozensage Whoever hangs the rangehood needs to make sure they allow for the thickness of the glass going behind it if they cut any holes in the ceiling for ducting before the glass is up. are there a standard thickness of glasses? 8mm for example? Re: Installing glass splash back behind rangehood 6Sep 03, 2010 10:50 pm frozensage frozensage Whoever hangs the rangehood needs to make sure they allow for the thickness of the glass going behind it if they cut any holes in the ceiling for ducting before the glass is up. are there a standard thickness of glasses? 8mm for example? Depends on the requested order and the type of glass splashback you have ordered Re: Installing glass splash back behind rangehood 7Sep 04, 2010 7:00 pm Bam Your cabinet maker wont install the rangehood (not that type anyway), your electrician should So once the cabinets are in, in comes your splashback, and then your electrician/plumber Depends upon the range hood. If it is hardwired then sure the sparkie needs to do it, if plug in then anyone can do it. My range hood is a large feature one, as opposed to the small under cabinet type and it is a plug in jobie. The power point is behind the duct cover. Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 524 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 381 2 4467 |
