Browse Forums Kitchen Corner 1 Jul 16, 2010 9:44 pm We are currently renovating our kitchen and have been given a gas wall oven. What I would like to know is how these are normaly mounted, I currently have a large recess in the wall from a wood cooker that was there many years ago, it has since housed a freestanding gas stove, I am cosidering boxing in this area to make a malimine cabinate for the oven to slide into, my concern is, do these wall ovens conduct enough heat on their exterior walls to become a fire hazzard if mounted in a wooden cabinate? Re: Installing a wall oven, advice needed 2Jul 20, 2010 2:14 pm crackatinny We are currently renovating our kitchen and have been given a gas wall oven. What I would like to know is how these are normaly mounted, I currently have a large recess in the wall from a wood cooker that was there many years ago, it has since housed a freestanding gas stove, I am cosidering boxing in this area to make a malimine cabinate for the oven to slide into, my concern is, do these wall ovens conduct enough heat on their exterior walls to become a fire hazzard if mounted in a wooden cabinate? Short answer is no. But strong virtue will always be found, In reading the manufacturers installation instructions. Sorry, tried to make this answer into a haiku to follow the theme of the previous random poster... Most modern ovens are manufactured to be integrated into generic cabinetry, which means they are normally well insulated around the oven cavity with excess heat being vented via the front rather than the sides or back of the unit, even the freestanding units. I an also refer you to the exact standards for installation of freestanding + integrated gas appliances if required viz. AS/NZS 4386.1:1996 + AS/NZS 4386.2:1996 Cheers, Earl Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6693 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6887 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15521 |
