Browse Forums Kitchen Corner 1 Jun 19, 2010 10:14 pm As the title suggests, has anyone used Brook Pebble or New Ash Dust Laminex for their kitchen bench tops? Brook Pebble (in real life the sample isn't quite so orangy brown) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ New Ash Dust Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We believe we've narrowed it down to either of the above colours for our bench tops now - we both think we prefer Brook Pebble but unsure what it would look like on a larger scale - wondering if the pattern will be a bit much?? We're going to go with Mushroom Linea for all cupboards & under benches on island bench Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and polar white cupboards / drawers on back wall Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So if you used either of these bench top colours, would you mind sharing a photo? Thank you Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Did anyone use either Brook Pebble or New Ash Dust Lamin 2Jun 20, 2010 11:16 am I have never used any of the colours but I do like these selections and I think I agree with the Brook Pebble over the New Ask Dust! Would you be using Diamond Gloss or the Natural finish for the benches? Sorry I can't be of any help I just thought I'd let you know I really like those colours together! Good Luck with your selections! Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: Did anyone use either Brook Pebble or New Ash Dust Lamin 3Jun 20, 2010 5:54 pm Hi, We've used new ash dust as our bathroom benchtops - we're very impressed with the colour. Below is a couple of photos - construction is still in progress so most of the benchtop is still covered with the plastic film, but you get the gist. Closeup: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And full view: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hope that helps! Re: Did anyone use either Brook Pebble or New Ash Dust Lamin 5Jun 21, 2010 8:11 pm Thank you both for posting your pics, I really appreciate it! It's helped a lot actually as I can see the Brook Pebble pattern is a little more subtle than I thought it might be which is great Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 the leaves that are now underground go yellow, the tips that poke through photosynthesise and have chlorophyll, same reason they grow rhubarb in the dark. 5 4886 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17886 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8315 |
