Browse Forums Kitchen Corner 1 Jun 04, 2010 3:24 pm Removing anything with any information about our build. If I was to win Lotto, I would build with a different builder, now to win lotto Re: Dishwasher Provision - What exactally should you get ? 2Jun 04, 2010 4:18 pm RoadkillNZ We have paid quite a bit for a dishwasher provision, and was wondering what exactally you get for that money ?, other than 1 less cupboard so the dishwasher can fit there. You should have also got a power point, taps under the sink to connect to and a connection under the sink to connect the drain line. How much extra did you get hit, as these items have a very minimal cost if factored in from the begging? Re: Dishwasher Provision - What exactally should you get ? 3Jun 04, 2010 4:30 pm Removing anything with any information about our build. If I was to win Lotto, I would build with a different builder, now to win lotto Re: Dishwasher Provision - What exactally should you get ? 4Jun 04, 2010 6:38 pm RoadkillNZ We got hit $650 which we thought was high, and expected to at least get the attachements by the dishwasher area, and holes precut to run the required wires/pipes through. But what we got is a power point in the cupboard next to it, a Tap on the wall quite a distance away from the space which we are presuming we are having to connect to. As for the drain, the sink is twice as far away from the dishwasher than the tap is, and can't see anything for the dishwasher unless it is a pipe that sort of just out of the S bend. Either way we are going to have to get extensions for both water and drainage for it to work and have a feeling after spending the money it would of been cheaper to not have it and get a plumber to put it in professionally later and it probably would be a better job because of the distances involved for the connections. Edit: Oh and the tap is only a cold tap, don't now if it should have a hot as well, but we know the dishwasher we want only needs a cold tap at least. Ouch that price seems a bit over the top. In regards to the tap, yes just cold is the norm, most if not all dishwashers nowdays run off just the cold tap, so don't worry about that. As for the drain, yes it is normally just a little bit sticking out of the S bend of the sink. Re: Dishwasher Provision - What exactally should you get ? 5Jun 04, 2010 6:55 pm We paid $250.00 for our Dishwasher Space - $650.00 seems expensive! |
