Browse Forums Kitchen Corner 1 May 20, 2010 11:07 pm Hallo, Anyone would be kind to help me with the height of the kickboard for my kitchen top please? i am planning to do timber flooring with batton (so it will be 40mm high in total) except the kitchen area where it will be using porcelain or tile (if the porcelain come out to be extremely expensive) and i want both porcelain and timber floor height to be FLUSH. (no sloping downward or upward) i think my kickboard height need to add additional 40mm to make it flush with my timber flooring although normally there is no need provision made for if i am going to use tile and 20mm provision if i use porcelain. am i correct in my thinking? will be very glad if someone can help me MP Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15922 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7753 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9567 |
