Browse Forums Kitchen Corner 1 May 09, 2010 11:49 am Hi guys, Which product(s) will give me that timber-look finish for the kitchen cupboards? See attached pic. I know of only Laminex. Is a laminate durable enough in the long run? I've seen some (in restaurants mostly) that peel off on the edges. Second question: how much more expensive is it, compared to plain-white polyurethane finish? Thanks!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to achieve that timber-look cupboards? 2May 09, 2010 12:46 pm Use a timber veneer for your cupboards, instead of laminate. Cost wise it's probably around the same as 2 pac finish, which are both a lot more expensive than laminate. The dark chocolate coloured look like what's in your pic looks like a wenge timber. Blog is now up - http://www.jbdave.blogspot.com/ Re: How to achieve that timber-look cupboards? 3May 10, 2010 12:39 am Thanks for the reply! How MUCH more do you reckon, for a reasonably sized kitchen (as per pic)? Re: How to achieve that timber-look cupboards? 4May 10, 2010 8:06 pm From my experience timber veneer is about the most expensive option you can chose. Looks great but you pay for it. Renovation Thread: viewtopic.php?f=31&t=38489 Interested in getting either the Polytec Boston Oak or Palace Peak for kitchen cabinets. Looking at the Boston Oak ones, it appears that the colour varies significantly… 0 9167 Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16585 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15905 |
