Browse Forums Kitchen Corner 1 Apr 30, 2010 2:21 pm Our fridge space is 510mm in depth. How much should it stick out by to open the doors, and how much can it stick out by reasonably? Confused.... It is in a walkway area, so I don't want to block it off, but I don't want a teeny tiny fridge either Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Re: How much can my fridge stick out by? 2Apr 30, 2010 3:29 pm larajane Our fridge space is 510mm in depth. How much should it stick out by to open the doors, and how much can it stick out by reasonably? Confused.... It is in a walkway area, so I don't want to block it off, but I don't want a teeny tiny fridge either Ours is 630mm deep and our fridge sticks out by 100mm (which is the door depth) and it goes all the way back apart from skirting. I actually wouldn't be able to open my doors if it were any further back due to the width of the space. Re: How much can my fridge stick out by? 3Apr 30, 2010 3:37 pm Well, that is good I suppose So we should probably allow for at least 100mm to stick out. I wish we had thought about the depth earlier! I want a fridge that would stick out by 200mm. I assume that is too much? So I am probably going to settle for 140mm, which is probably still a lot. Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Re: How much can my fridge stick out by? 5Apr 30, 2010 4:04 pm Alright thanks I'll go with the 140mm one. Our CSR gave us those figures, and I think they might have been approximate, so I am hoping the depth is actually larger! But don't want to get my hopes up to much Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Re: How much can my fridge stick out by? 6Apr 30, 2010 4:47 pm I think ours is 150mm and it's fine. It's also in a walkway area. I was worried about it too but it's just fine. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: How much can my fridge stick out by? 7Apr 30, 2010 6:44 pm Ours is 100mm (the depth of the doors) which looks good. Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: How much can my fridge stick out by? 8Apr 30, 2010 6:47 pm Alright, well we will have to get the exact depth measurements. I will probably allow up to 150mm. Wish we could have a bigger fridge!! Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6163 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7550 7 12025 |
