Browse Forums Kitchen Corner Re: Oven Capacity: 66L Vs 60L - How much difference does it 2Apr 28, 2010 3:57 pm Would you pay 35% more for an extra 6L (and some extra features eg. Fan heat, Top heat, AutoRoast, MoisturePlus, Sabbath, Automatic programmes, User programmes and 60cm(W) x 60cm(H) instead of 70cm(W) x 48cm(H)? Re: Oven Capacity: 66L Vs 60L - How much difference does it 3Apr 28, 2010 4:13 pm 1 litre = 1 cubic decimeter (or abbreviated, 1 l = 1 dm3). (Note: 1 dm = 10 cm) Since 1 dm3 = 10x10x10cm, and you have 6 of those (6l), you can end up with a quadrant 60 cm high, 10 cm wide and 10 cm deep. This is the simplest shape you can get from this size and easiest to explain. When "translated" to a real object (an oven), you will have a much flatter object, more like a rectangular/square board (maybe like a really really really thin DVD player). My signature is distracting people from my wise posts ... Re: Oven Capacity: 66L Vs 60L - How much difference does it 4Apr 28, 2010 4:19 pm Huh! Seems like you got the dimensions. The feature that I am always after is the fan, manually controlled is best for me I can probably live without the rest. Not sure what exactly they mean by Fan heat. Top heat sounds like top griller - maybe not bad ... My signature is distracting people from my wise posts ... Re: Oven Capacity: 66L Vs 60L - How much difference does it 5Apr 28, 2010 4:36 pm Lex Huh! Seems like you got the dimensions. The feature that I am always after is the fan, manually controlled is best for me I can probably live without the rest. Not sure what exactly they mean by Fan heat. Top heat sounds like top griller - maybe not bad ... Thanks Lex. I've changed the topic as I failed to express myself properly the first time Re: Oven Capacity: How much difference does 12cm (H) make? 6Apr 28, 2010 4:58 pm OK, my ramblings for your new topic : Can you have 2 trays at once in the smaller oven (one above another)? If not, then it's better to have 12cm extra H, so that you can have better spacing between the 2 trays, becuase better spacing means better baked result. My signature is distracting people from my wise posts ... DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8991 Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2085 if i have understood your dimensions correctly my suggestions include using the smallest toilet and wall hung handbasin eg Caroma Urbane with in wall cistern, small wall… 1 8173 |
