kitchen pantry
....we want to build a walk in pantry 2.5mt x 1.8mt. The rest of the kitchen will be cabinet free except for some open shelves and a couple of draws.
Sorry, can't help at all with the temperature/humidity thing, but I'm curious about what will be in your kitchen, if not cabinets? What's going to hold up the benchtops?
That doesn't help with a sink though...
Sounds interesting. More info?
I had a pantry in an old house. It had only a small window which didn't receive sun and stayed cool.
If you heat your kitchen it is important as well to think on the pantry door, it must be closed all the time and I don't know maybe a better door would make a difference. You could as well put ventilation openings in. And the fridge must be kept outside the pantry as it creates heat.
Basically NO there is too much temperature difference and humidity to process optimally meats and things like that even preserves need low humidity environment.
I did quite a few salted cured raw hams, waxed salamis but temp and ventilation was always the main concern.
3
Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of…
12/01/2024
2
I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on…
6/06/2023
1
No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s
