Browse Forums Kitchen Corner Re: Thickness of 2 pak doors - 18mm or 25mm? 2Apr 02, 2010 7:01 am SYD-YYZ Is there any advantage of either? no discernable difference except for the cost of the extra thickness ,although the thicker panels do look better on waterfall ends but i would use 33 mm thick as they look chunkier Re: Thickness of 2 pak doors - 18mm or 25mm? 3Apr 02, 2010 8:10 pm arms SYD-YYZ Is there any advantage of either? no discernable difference except for the cost of the extra thickness ,although the thicker panels do look better on waterfall ends but i would use 33 mm thick as they look chunkier I am not having waterfalls. Most companies have quoted me the 18mm doors except one (which is 25mm) - I didn't ask for it. Maybe I should just ask them for the 18mm? Re: Thickness of 2 pak doors - 18mm or 25mm? 6Apr 02, 2010 8:48 pm borg go 18mm. 25mm are wrong they will be to heavy and your doors will sag. without being offensive to the reply ,rubbish ,modern day hinges of any quality will hold up to 15 kg of weight easily Re: Thickness of 2 pak doors - 18mm or 25mm? 7Apr 02, 2010 8:55 pm arms borg go 18mm. 25mm are wrong they will be to heavy and your doors will sag. without being offensive to the reply ,rubbish ,modern day hinges of any quality will hold up to 15 kg of weight easily I was waiting for a reply of such. It all comes down to the dimensions of the door. If you had a short but wide door that weighed the same as a tall but narrow door does this mean they will perform the same???? The case is no!!!! It not only a function of weight. Its not all about the weight. A well designed kitchen should last many years unfortunatley people only design kitchen to last a few years. Why put extra weight in doors if they dont add any benefit, you doors only need to sag a little for the lines not to match up neatly. Re: Thickness of 2 pak doors - 18mm or 25mm? 8Apr 02, 2010 10:10 pm SYD-YYZ Is there any advantage of either? Will your door be routed with a pattern? A 25mm thick door would be a better option if your door was to be routed and if the inner part of the doors was to be recessed routered. The thicker door will lessen the chance of the door bowing after it has been painted. For taller painted doors (i.e pantry doors) it is advisable to use a thicker substrate as they tend to bend or warp more readily once they have been painted. Re: Thickness of 2 pak doors - 18mm or 25mm? 9Apr 03, 2010 6:49 am borg arms borg go 18mm. 25mm are wrong they will be to heavy and your doors will sag. without being offensive to the reply ,rubbish ,modern day hinges of any quality will hold up to 15 kg of weight easily I was waiting for a reply of such. It all comes down to the dimensions of the door. If you had a short but wide door that weighed the same as a tall but narrow door does this mean they will perform the same???? The case is no!!!! It not only a function of weight. Its not all about the weight. A well designed kitchen should last many years unfortunatley people only design kitchen to last a few years. Why put extra weight in doors if they dont add any benefit, you doors only need to sag a little for the lines not to match up neatly. a well designed kitchen will not incorporate over square doors ,so if your doors are over square (wider than high) it will not be the hinges that fail or drop it will be the lack of thought of the designer at fault Re: Thickness of 2 pak doors - 18mm or 25mm? 10Apr 03, 2010 12:20 pm renomart SYD-YYZ Is there any advantage of either? Will your door be routed with a pattern? A 25mm thick door would be a better option if your door was to be routed and if the inner part of the doors was to be recessed routered. The thicker door will lessen the chance of the door bowing after it has been painted. For taller painted doors (i.e pantry doors) it is advisable to use a thicker substrate as they tend to bend or warp more readily once they have been painted. Thanks. There will not be a pattern - just plain white kitchen. Re: Thickness of 2 pak doors - 18mm or 25mm? 12Apr 03, 2010 5:06 pm borg to stop two pack doors from bowing is is best to use board that has laminte on both sides. With the face to be roughly sanded for the two pack to stick. not sure whether you are taking the mickey out of us ,but when you are to use two pack paint most boards are mdf coated on both sides with a MELAMINE coating to fully seal the board ,if you are not taking the mickey ,now you know how this industry works Re: Thickness of 2 pak doors - 18mm or 25mm? 13Apr 04, 2010 8:30 am arms borg to stop two pack doors from bowing is is best to use board that has laminte on both sides. With the face to be roughly sanded for the two pack to stick. not sure whether you are taking the mickey out of us ,but when you are to use two pack paint most boards are mdf coated on both sides with a MELAMINE coating to fully seal the board ,if you are not taking the mickey ,now you know how this industry works Sorry your absolutly right. The correct name is melamine. Some cabinet makers use board that only have melimine of one side which can cause the doors to bow. in regards to two pack I find it best to use boards that have melamine on both side for the reasons you have described above. we have a standard size and often we have a lot of variety to choose 0 3577 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5042 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4355 |
