Browse Forums Kitchen Corner 1 Mar 21, 2010 2:01 pm We finally have our kitchen installed, but when I had a good look the gaps in some cupboards seem quite large 4mm or am I being just fussy. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ corner gap. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ middle gap. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have taken the measurement from the outer edge of the binding. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Are these gaps to big? 3Mar 21, 2010 3:03 pm I'm not sure what a tolerence is 'allowed' but I wouldn't be happy with that at all!! Lots of room for cocky's ect to crawl into. That corner 1 in particular is pretty bad IMO, I haven't seen cupboards with gaps like that before ____________________________ Bec ____________________________ Building our Balinese Resort Inspired Dream Home Blog ~ http://hagarshouse.blogspot.com/ Re: Are these gaps to big? 4Mar 21, 2010 3:44 pm That corner gap is terrible. I cant see into my corner cupboard at all as it sits fairly flush. I had a problem with gaps on my island unit after the waterfall stone ends or the tradie that installed the stone, moved my cupboards to fit but hubby managed to fix it. There is a way to adjust the drawer fronts so maybe you can play around with that to move some of those gaps closer. Maybe the corner unit can also be adjusted. Re: Are these gaps to big? 6Mar 21, 2010 4:10 pm I think Southies is right.... also, the door hinges need some adjusting, which is usually done before handover anyway to make sure doors are straight (check out the height difference in the second photo). I bet that closes some gaps a little. Re: Are these gaps to big? 7Mar 21, 2010 5:01 pm Your doors dont appear to have been adjusted as of yet, like Kek mentioned. You can tell this as they arent aligned up the top in one of your pics. Once they are adjusted, they will sit much better Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Are these gaps to big? 8Mar 21, 2010 8:21 pm I am going to chase up the builder to see if all the adjustments have been done, it a concern as the gaps in the overheads and other cupboards are smaller there seems to be not consistancy. I have paid extra to have the laminate laid horizontally so they should have made the allowance for the extra material need. Even the cupboards in our crappy rental have smaller gaps and sit better. Will go do some pesterig... Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19378 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7612 Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 7173 |
