Hi all
I just noticed on my Caesarstone waterfall edge, a sticky tape mark - quite wide - possibly from when it was packed.
I've tried soapy water, general purpose ammonia-based cleaner but the shadow is still there. Any suggestions?
Browse Forums Kitchen Corner 1 Mar 17, 2010 3:35 pm Hi all I just noticed on my Caesarstone waterfall edge, a sticky tape mark - quite wide - possibly from when it was packed. I've tried soapy water, general purpose ammonia-based cleaner but the shadow is still there. Any suggestions? After 4 years - we're in! Re: Removing sticky tape mark from Caesarstone 4Mar 17, 2010 5:32 pm Smooth Peanut Butter (has to be smooth)!! Works a treat. Just put it on and leave for about 10 minutes, then it wipes off. If still tough, it's waaaay easier to clean with other "normal" methods (I use bicarb soda+vinegar together) (hopefully it shouldn't leave a greasy mark ) My signature is distracting people from my wise posts ... Re: Removing sticky tape mark from Caesarstone 7Mar 17, 2010 7:34 pm Yep, tm, I was surprised too. Found out only recently and have been totally "converted" ever since It has some oils which disolve some chemicals in glues. Cleaned soooo many things already (mostly book covers, even plastic covers, glass is super easy, ...). BUT then: I had a beautiful small bowl which I almost broke trying to remove the sticky label from the face of it . Scrubbed and scrubbed, using all possible chemicals I could think of - nothing. Finally gave up and covered it with stuff and it was sitting for about 1 year. And then came PB ... had to re-apply it about 3 times ... but the glue finally gave up so I was able to scrub it off just with a rough (=cheap ) paper towel !! So now I have a brand new bowl My signature is distracting people from my wise posts ... Re: Removing sticky tape mark from Caesarstone 9Mar 18, 2010 9:46 am Thanks everyone! I think I have peanut butter at home - will try it tonight After 4 years - we're in! Re: Removing sticky tape mark from Caesarstone 10Mar 18, 2010 10:03 am kek Orange oil. ditto! or something like windex might work ok too. something strong with lots of chemicals "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the… 5 9710 6 11261 The best advice is for you to get a competent building consultant to guide you through your build 7 4711 |
