Browse Forums Kitchen Corner 1 Mar 13, 2010 3:27 pm Hi, Please see my house plan below. I want to increase the size of the kitchen. We have a double door fridge / freezer and it seems to be taking bulk of the place in the kitchen. Can you please try and rearrange my kitchen so i have bit more kitchen working space around the hot plates and at the same time fit the freezer and a little bit bigger pantry. Even if this means to connect the island bench and not have a open plan. Please provide your ideas. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 3Mar 13, 2010 4:06 pm No, i want it to stay at the same area. Thanks Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 4Mar 13, 2010 4:20 pm Hi mark299, You could move pantry into corner (walk-ins are great!!), frg/frz into old pantry space (extend wall slightly to fit fr/fr size) & have all the back bench as working space, apart from cooktop & also put in overhead cupboards for loads more storage. Mine is kind of similar so have a squiz to see what i mean. There is someone on home1 called "somewoman" who is absolutely brilliant in coming up with house plan ideas, maybe she will see your post & give you some advice. Cooper's Build - Perth NOR viewtopic.php?f=31&t=30525 Prelim- mid Sept 2009, Pre Start 2 Feb, Siteworks- 21 April 2010, Slab- 10 May, Deliveries- all by 26 May Bricking- 28 May - 26 June, Roof complete 5 Aug, Float 28 Aug, Lock up 16 Sept Cabinets 1 Oct, Tiling 22 Oct, PCI 18 Nov, KEYS 3 Dec 2010 MOVED IN 17 DEC 2010 Re: Design Help in increasing size of kitchen 6Mar 13, 2010 4:37 pm great. how about as cooper32 said, if i move the fridge where pantry is, and then in the corner of the fridge and the hot plate side place the corner pantry? will this work, that way i have full bench almost. Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 7Mar 13, 2010 8:44 pm Sounds good to me!!!! Cost wise this should be minimal as you are simply moving things around so might just be extra pantry shelving (now that it's a corner pantry with 2 usable walls of shelving as oposed to 1) & an extra 500mm or so to fit your frg/frz in nicely. Personally i would level that wall up with oposite wall (internet room). Look forward to seeing how things progress. Cooper's Build - Perth NOR viewtopic.php?f=31&t=30525 Prelim- mid Sept 2009, Pre Start 2 Feb, Siteworks- 21 April 2010, Slab- 10 May, Deliveries- all by 26 May Bricking- 28 May - 26 June, Roof complete 5 Aug, Float 28 Aug, Lock up 16 Sept Cabinets 1 Oct, Tiling 22 Oct, PCI 18 Nov, KEYS 3 Dec 2010 MOVED IN 17 DEC 2010 Re: Design Help in increasing size of kitchen 8Mar 13, 2010 9:50 pm Re: Design Help in increasing size of kitchen 9Mar 13, 2010 9:56 pm another option to add a LOT more space to your kitchen is to eat into your internet room a little bit and add further bench or pantry along that wall. If you still want to allow light into this room you could have your wall openings facing into the dining area. Re: Design Help in increasing size of kitchen 10Mar 13, 2010 9:58 pm What's the length of the kitchen wall where the oven will go? Re: Design Help in increasing size of kitchen 12Mar 13, 2010 10:29 pm how about this, will this work. The only issue with putting the pantry by eating into internet room is, if we put pantry there, then the doors of the pantry will be always blocking the only pathway to access the rest of the house. how is this below. please comment. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 13Mar 13, 2010 10:32 pm somewoman, i like the way you changed it the first time, by putting the pantry in the junction corner of the two sides, and it looks like it will have more space. thanks Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 14Mar 13, 2010 10:42 pm I think the corner pantry is better than the larger straight pantry in the same location - but only because lengthening your kitchen wall like that encloses the study "windows". If you were to either move the holes in the study wall or cut them out completely it might feel a little better. If you like the pantry along that internet room wall, could you look at using sliding doors? Or possibly more doors so that the opening space for each door would be smaller, thus it wouldn't stick out so far into your pathway? I also think it is well worth considering changing your laundry to include storage on both sides of the walkway - standard benches (possibly overheads) on the wall with your machine, then thinner linen on the opposite wall. Makes a massive difference to storage ability within your home, and looks WOW! =) Re: Design Help in increasing size of kitchen 15Mar 13, 2010 11:27 pm somewoman I think the corner pantry is better than the larger straight pantry in the same location - but only because lengthening your kitchen wall like that encloses the study "windows". If you were to either move the holes in the study wall or cut them out completely it might feel a little better. If you like the pantry along that internet room wall, could you look at using sliding doors? Or possibly more doors so that the opening space for each door would be smaller, thus it wouldn't stick out so far into your pathway? I also think it is well worth considering changing your laundry to include storage on both sides of the walkway - standard benches (possibly overheads) on the wall with your machine, then thinner linen on the opposite wall. Makes a massive difference to storage ability within your home, and looks WOW! =) Can you please show me in drawing (if possible) how you are asking to change the laundry. What you say sounds really interesting, but i am not able to fully understand it. Thanks Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 16Mar 14, 2010 12:32 am Re: Design Help in increasing size of kitchen 17Mar 14, 2010 12:35 am thank you Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 18Mar 14, 2010 1:14 am Our linens in our laundry have a depth of 450mm, and are absolutely perfect. Also have a broom cupboard in with them. SO much storage =))) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ we have a front loader washing machine, so have made the benchtop go the entire length of the wall. The far end with the weird panel in front is where we will put our cats kitty litter (in an attempt to block them from scattering it everywhere), but this space would have been more cupboards if we didn't have cats. The door to outside is glass to allow in natural light - it is also north facing so we could probably use this room to dry clothes in very easily from the heat generated from the northern sun (if we weren't fearful of having kitty litter scented clothing!!). Re: Design Help in increasing size of kitchen 19Mar 14, 2010 1:19 am very nice. That would be heaps of storage. and lol @ kitty litter smelly clothes Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Design Help in increasing size of kitchen 20Mar 17, 2010 12:38 pm I need help, in the above design to add a microwave Recess area somewhere, using the same area available in the kitchen. Can someone please give me ideas. Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 1 1923 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15303 G'day I'm trying to put in some privacy screening on my rental rooftop on a tight budget. I've already invested about $500 in the supplies for this. The issue is… 0 32243 |
