Browse Forums Kitchen Corner Re: Anyone seen/used this kitchen design software before?? 2Feb 17, 2010 7:47 am Jose27 Hi, has anyone used this software before? http://www.itbureau.com.au/Default.aspx It it any good? Is it easy to use? Thanks Jose the software is 20/20 ,i have come across it in the past ,reasonable to use ,can do most applications ,this version is set up to use laminex products so as long as you can adapt the plan to your needs it should do whatever you require ,all you need to do is substitute different materials for the laminex products if you wish As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17868 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15303 |
