Browse Forums Kitchen Corner Re: kitchen benchtop help needed - no joins! 41Feb 01, 2010 5:08 pm How about having honed (or polished) concrete? This is an NZ website I just pulled up, but gives you a bit of an idea. . . http://www.customconcrete.co.nz/benchtops.html Re: kitchen benchtop help needed - no joins! 42Feb 01, 2010 5:52 pm There are a few manufacturers here in Oz. Some advertise and others don't ![]() Most of the following photos are of W/I/progress so the finish is yet to be completed ![]() Also the scope of the works can vary as some clients want a particular finish IE: 'off form' 'Honed' 'polished' 'agricultural' etc so I have slotted a few that met or exceeded the clients 'wants' Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 43Feb 01, 2010 5:58 pm I can't belive that the top pic's not granite onc!!!
What you could do I suppose, is have the island bench in honed concrete or corian, then have your other benchtops in a contrasting stone??? I've seen some lovely pictures of kitchens where they have contrasting stone benchtops on the island and wall-benches. Re: kitchen benchtop help needed - no joins! 44Feb 01, 2010 6:06 pm The top one is resin filled stone only... But yes mixed media is something that needs a careful eye with the mixes... So long as the hue is the same, I haven't noticed an issue. Also, the rules have been broken now, so anything goes. Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 46Feb 01, 2010 6:26 pm I love it Onc!!!! ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: kitchen benchtop help needed - no joins! 47Feb 01, 2010 6:33 pm Yeh, just need to find them ![]() Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 48Feb 01, 2010 6:41 pm The 4th one down ^^^ is a white vanity one of 2 for the house ![]() Though it will never get to be bright white. And if your intention was to grind them then you would need white cement white stone and white sand or the grinding of the non-white stones and sand would 'bleed' into the 'white' ![]() ![]() Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 49Feb 01, 2010 8:10 pm Re Granite transformations and joins: In about 2000, we upgraded the benchtops and splashbacks in our previous house with this mob. Overall, it was excellent....one of the best upgrades we ever did. The joins (4 at the corners of each of the sink and cooktop) were simply a non-issue. You couldn't see them unless you looked specifically for them. Like most things, though, it depends on the tradies doing the job. ![]() This is a corner of the 30 yo kitchen. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is a join at the cooktop edge. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here, I've used a severe closeup with lighting to make the join as bad as it could possibly be.....still pretty acceptable IMHO. ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I reckon similar results should be achievable wherever a join is absolutely necessary in any engineered stone product, which are generally available in finite lengths. Cheers zeke DIY, Home Maintenance & Repair It would be difficult and require removal for machining in a workshop. Not sure what the edge treatment is on that but perhaps pencil round? might cause some dramas in… 1 5321 Hi guys, Painters or anyone who has experience applying Zinsser Bin (shellac based) help and advice is appreciated I have used two thick coats of Zinsser bin to block… 0 2813 Here's what I've come up with after playing around for a bit: - Sink facing Alfresco - Bench space to left and right of sink for "water-related" appliances (e.g., soda… 1 4769 |
