Browse Forums Kitchen Corner Re: kitchen benchtop help needed - no joins! 41Feb 01, 2010 4:08 pm How about having honed (or polished) concrete? This is an NZ website I just pulled up, but gives you a bit of an idea. . . http://www.customconcrete.co.nz/benchtops.html Re: kitchen benchtop help needed - no joins! 42Feb 01, 2010 4:52 pm There are a few manufacturers here in Oz. Some advertise and others don't Most of the following photos are of W/I/progress so the finish is yet to be completed Also the scope of the works can vary as some clients want a particular finish IE: 'off form' 'Honed' 'polished' 'agricultural' etc so I have slotted a few that met or exceeded the clients 'wants' Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 43Feb 01, 2010 4:58 pm I can't belive that the top pic's not granite onc!!!
What you could do I suppose, is have the island bench in honed concrete or corian, then have your other benchtops in a contrasting stone??? I've seen some lovely pictures of kitchens where they have contrasting stone benchtops on the island and wall-benches. Re: kitchen benchtop help needed - no joins! 44Feb 01, 2010 5:06 pm The top one is resin filled stone only... But yes mixed media is something that needs a careful eye with the mixes... So long as the hue is the same, I haven't noticed an issue. Also, the rules have been broken now, so anything goes. Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 46Feb 01, 2010 5:26 pm I love it Onc!!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: kitchen benchtop help needed - no joins! 47Feb 01, 2010 5:33 pm Yeh, just need to find them Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 48Feb 01, 2010 5:41 pm The 4th one down ^^^ is a white vanity one of 2 for the house Though it will never get to be bright white. And if your intention was to grind them then you would need white cement white stone and white sand or the grinding of the non-white stones and sand would 'bleed' into the 'white' clear as mud??? Where you are coming from is where you are going to... Re: kitchen benchtop help needed - no joins! 49Feb 01, 2010 7:10 pm Re Granite transformations and joins: In about 2000, we upgraded the benchtops and splashbacks in our previous house with this mob. Overall, it was excellent....one of the best upgrades we ever did. The joins (4 at the corners of each of the sink and cooktop) were simply a non-issue. You couldn't see them unless you looked specifically for them. Like most things, though, it depends on the tradies doing the job. This is a corner of the 30 yo kitchen. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is a join at the cooktop edge. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here, I've used a severe closeup with lighting to make the join as bad as it could possibly be.....still pretty acceptable IMHO. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I reckon similar results should be achievable wherever a join is absolutely necessary in any engineered stone product, which are generally available in finite lengths. Cheers zeke Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12926 You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 15610 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
