Hi All,
I am after some advice for the selection of our splashback. I understand the difference between "Clear" & "Starphire" & that if you want the true colour to be represented then you must use Starphire glass as Starphire glass allows the true colour to come through the glass.
Does this only apply to lighter colours????
If using a darker colour, ie Mocha or Java Dusk, do I still need to use Starphire glass or can you get away with using the "Clear" glass for darker colours?
Thanks for your help.
