Browse Forums Kitchen Corner Re: Bosch Dishwasher, Cold Water "Recommended" - Does it matter? 7Feb 11, 2010 3:55 pm perthhomelover I have a Bosch Dishwasher for the past 10 years, and have run it on hot water. Is says the temp should never go over 60c. I hope this assists. I have a continuous HWS, they're supposed to have a limiting valuve to 50 or 60deg but not sure and given my plumbers other issues/comments I have no idea what it is set to. I don't have any controllers in the house so it is whatever the unit is set to. But the comments about hot water only being used when the unit makes sense to me. All the new washing machines are like that I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2714 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12666 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2608 |
