Browse Forums Kitchen Corner Re: drilling a larger hole in ceaserstone bench top 2Jan 29, 2010 2:13 pm You can use a special hole saw. However they are harder to use as they have no pilot. They one it is started off is by using a high speed drill and then starting on a 45 degree angle then bring it up straight once it starts. Do you have an off cut to pratice on? Re: drilling a larger hole in ceaserstone bench top 3Jan 29, 2010 11:13 pm cut a hole the size you need in a piece of mdf about 500mm x depth of bench then clamp this over where you want to drill to use as a guide or you can stand on the board as you drill I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7085 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31263 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3796 |
