Browse Forums Kitchen Corner 1 Jan 28, 2010 7:15 pm The plumber who installed my kitchen sink didnt seal the joins between the stone benchtop and where the sink makes contact with it. I thought this would be a standard practice....do I need to tell him to do it? When I asked him about it he said that silicon would only go mouldy. I have noticed that there is moisture now underneath the cupboards. Re: Sealing a newly installed kitchen sink 2Jan 29, 2010 1:08 am If you use a polyurethane the service life is heaps better then silo.. Where you are coming from is where you are going to... Re: Sealing a newly installed kitchen sink 4Jan 29, 2010 8:06 am camelia Do you mean Sikaflex? If so, which one? I'd say a marine grade sikaflex in a caulking tube would probably suit, just need to make sure its one of the adhesive polyurethane types, a quick trip down to bunnings (or equivalent) in the adhesives section would see you right. Best yet its available in a number of colors so you should be able to pick one that doesnt stand out like the proverbial. I've used it as an adhesive for bonding fibreglass parts on my sea kayak with great sucess so i think it would withstand sealing a sink. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Sealing a newly installed kitchen sink 6Jan 29, 2010 1:47 pm If i recall correctly, i think mine was the 291 product or somesuch in a caulking tube and was available in the same grade in Black (which i used), white, grey, brown and maybe clear. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Sealing a newly installed kitchen sink 7Jan 29, 2010 2:05 pm thanks belial, I also noticed a foam sealing strip which the plumber left out...should it be used together with the silicon? I think I can do this myself, easier than getting him back Re: Sealing a newly installed kitchen sink 8Jan 29, 2010 2:57 pm TBH not sure, a quick google around the place on kitchen sink installation tends to only mention putting a bead of adhesive around the inner edge to seal it to the benchtop. Otherwise is the sink branded at all? Might be worth chasing up the manufacturer for an install guide, enquiring on the basis that your plumber left out the strip and whether it is or is not required based on the manufacturer install requirements and hence wether you would need to get said plumber to come back and fix it. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Sealing a newly installed kitchen sink 9Jan 29, 2010 9:22 pm The sink was supplied by the kitchen company and its made in china (unbranded). They didnt supply the plumber...who has his own agenda and it seems has difficulty determining what should go on the left and what should go on the right (ie, he mixed up the hot and the cold taps) Re: Sealing a newly installed kitchen sink 10Jan 30, 2010 8:01 am camelia The sink was supplied by the kitchen company and its made in china (unbranded). They didnt supply the plumber...who has his own agenda and it seems has difficulty determining what should go on the left and what should go on the right (ie, he mixed up the hot and the cold taps) the neoprene strip has to be fitted to make the sink waterproof , a bead of silicone will not be enough to stop water penetration ,and a true sanitory silicone is what is needed to seal the wall tiles and the bench ,sounds like you have really picked a doozy in regards to the plumber The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15783 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1192 |
