Browse Forums Kitchen Corner 1 Jan 19, 2010 11:56 am my builder included a rangehood above my stove, but no flume to take that smoke into the ceiling and through the roof! had i known about this, i would have obviously included a flume at prestart. anyway, what tradie could install a flume for me?? roof carpenter, sparky?? cheers Re: what tradie installs flumes in kitchen ceiling? 2Jan 19, 2010 12:24 pm Roofing plumber. You don't really want the rangehood venting into the ceiling space, in fact it might not even be legal, though the rules about that seem to change from time to time and from one council to another. Definitely don't vent into the ceiling if you have sarking. Check the instructions. Things to watch for are - whether the rangehood came with a vent kit (like our current one) if not then the correct diameter of pipe (like our old one, if they install a smaller pipe the fan doesn't work as efficiently) whether anything in the rangehood needs to be removed/switched over when you convert from recycling to external operation (we've had externally vented rangehoods in two new houses installed incorrectly because the installers didn't know that the secondary filter isn't required when venting outside so they didn't remove it and also they didn't switch something over to direct the airflow correctly). Unless there were unforeseeable issues with the site, I dont think you should have to pay for contractors errors or poor planning. I'd probably try and be reasonable and… 5 1857 Thanks for sharing. Looks good. The joiner has come back with a quote of close to 5k. I think we are going to not do it. Attaching panelling is something they are dead… 11 10123 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 7328 |
