Browse Forums Kitchen Corner Re: Integrated Dishwasher finished cycle? 5Jan 18, 2010 9:52 am lucyshouse I've got the bosch fully integrated one ... it does have a light that shines at the floor so you know when it is on Ditto - same model, and the light is cool I'm not so fussed about not being able to see the progress of the cycle as I generally set it off shortly before bed time and just let it churn away while I'm asleep! Re: Integrated Dishwasher finished cycle? 6Jan 18, 2010 3:12 pm I run mine at night usually too .. but I wish I knew how to disable the noise it makes when it is finished .... argghh!! I've tried playing with the settings but it doesn't seem to stop it ... and the timing of the beeping is just enough for me to slip off into sleep before it goes again!! Re: Integrated Dishwasher finished cycle? 7Jan 18, 2010 9:06 pm lucyshouse - are you saying that your's keeps beeping when it has finished? that would really annoy me, what brand is it ? Anyone with experience with the Mielle? Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: Integrated Dishwasher finished cycle? 8Jan 19, 2010 8:47 am I know with the top model of miele fully integrated dishwasher, it'll flash a red light after the cycle is finished for about an hour and you can choose to turn the buzzer on or off. And at the end of the cycle the door will open slightly by itself for better drying (and to let you know it's finished). Brilliant! Re: Integrated Dishwasher finished cycle? 9Jan 19, 2010 9:07 am Jaeger LeCoultre - So no indication when the dishwasher is running on that Meile? The door opening slightly at end of cycle is good. My experience is my semi Bosch ends up with a near dry load (without door opening), but my brothers dishwasher (dont know brand, but most likely a high end) left all the dishes quite wet. Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: Integrated Dishwasher finished cycle? 10Jan 19, 2010 12:14 pm i had a fully on the last house, the only issue i had with it was that when we where selling there had to be a note on it saying it was a dishwasher so people even noticed it. I would love an integrated fridge if they where not so stupidly expensive. Ours didn't have an indicator light and was damn quite but it was only ever me and one other living in the house so i tended to know when it was on, good to hear they have put a light or similar on them. Mine used to beep a few times when it finished. Re: Integrated Dishwasher finished cycle? 11Jan 19, 2010 12:49 pm 71monaro Jaeger LeCoultre - So no indication when the dishwasher is running on that Meile? The door opening slightly at end of cycle is good. My experience is my semi Bosch ends up with a near dry load (without door opening), but my brothers dishwasher (dont know brand, but most likely a high end) left all the dishes quite wet. i don't think the miele tells you anything when it's on, only when it's finished. If you want dishwashers with better drying, try to look for ones with fan drying( eg. Asko) or condenser drying/ heat exchanger, etc. For a miele, look at the roof inside the dishwasher, if there's a vent at the front right hand corner then it has better drying. Or look for miele ones with 'Drying Plus' function ( automatic door opening). 2 2531 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2716 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46966 |
