Browse Forums Kitchen Corner 1 Jan 10, 2010 4:01 pm Hi there, Seems like some companies have 1mm edging and some have 2mm edging on their melamne / laminate doors. Does it make much difference in quality or looks? Should it influence which company I decide to use? Thanks Re: Pros and Cons - 1mm vs 2mm edging on melamine/laminate doors 2Jan 10, 2010 4:18 pm Hi little buddy, The supplier we went with only offered a 1mm PVC edge strip with the gloss white we chose, however, all the other colours came with a 2mm PVC edge strip. At the end of the day, I suppose a 2mm edge would be more durable; but really, it's just the edge of the door and unless you plan to be using your Kitchen cupboards like some sort of an amusement park, there shouldn't be any problem hehehe Also, I haven't noticed any issues with the edge strip and moister - that is, the doors beneath the sink do get wet sometimes if I'm splashing about with the dishes... but thus far everything stood up to the test!. Good luck!! Re: Pros and Cons - 1mm vs 2mm edging on melamine/laminate doors 3Jan 11, 2010 8:19 am little buddy Hi there, Seems like some companies have 1mm edging and some have 2mm edging on their melamne / laminate doors. Does it make much difference in quality or looks? Should it influence which company I decide to use? Thanks the in look today is the square form ,this explains the prevelance of materials with a sharp finish to edges , the 2mm is ABS and usually has a slight round to the edge and more likely to not show abuse ,the 1mm is PVC and usually has a sharper edge and will take a bit of abuse ,they are both held on by the same glue ,so it all depends on the look you are trying to achieve as to what thickness you need Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 11982 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4909 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6317 |
