Browse Forums Kitchen Corner Re: Drawer inserts question - layers? 9Jan 05, 2010 2:15 pm lucyshouse Have done some photos on my blog (since I haven't worked out how to make pics work here!): 1. Just right click on your blog photo, select "Copy Image Location" 2. Go bakc to your H1 post, click on "Img", which is found in the menu above the post box 3. Paste the copied link in between the 2 bracketted "Img". And that's what you do anytime you want to paste a pic in your post, found on the net. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9971 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 1 13128 |
