Browse Forums Kitchen Corner Re: Internal Pantry Drawers 3Dec 13, 2009 11:08 pm viewtopic.php?f=31&t=22766 - my build thread! Time waits for no man. Unless that man is Chuck Norris. Re: Internal Pantry Drawers 4Dec 14, 2009 11:10 am buildingadreamhome I want to get some drawers for my pantry that I can install inside the pantry itself behind the doors. I have found some wire ones in Bunnings but I prefer ones that look similar to these Ikea ones that unfortunately don't fit: Our external cupborard measurement is 700mm and internal is 666mm. I'd like to be able to buy them direct and not from a kitchen company (with their mark up!!) Does anyone know of where I can buy them?? If I can buy them?? these are standard profile drawers with an inner drawer kit ,you will have to get a bottom,back and front specially cut to fit your cabinet also you will have to allow for spacers to let the drawers slide past the hinges of the door ,all up you will really be better off getting someone to make them for you ,unless of course you have the neccesary machinery and access to the tolerances for this drawers construction Like pulse said, you can fit drawers however because of the placement of the sink there isn't much depth so you would have to have cut outs for the waste pipes. It all… 2 1299 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5203 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44072 |
