Browse Forums Kitchen Corner 1 Oct 19, 2009 1:44 pm Hi All, Trying to come up with a new kitchen design for the small space in an apartment. Space is very limited so every millimetre counts. The goal is to use a flatpack system but I'm a newbie to all this. I'm a little confused a about the infill/end panels and when they need to be used. I understand they need to be used when a cabinet finishes against a wall or has an exposed face. A couple things I am unsure about though .... - Is there a standard width for these panels or does it depend on the cabinet manufacturer? - Should infill/end panels be used in the following.. - If the overhead cupboards change in height? (i.e. a microwave cabinet will hang lower than a standard cupboard it is next to) - When using an underbench oven cabinet, should the infill panels be on either side? - On either side of the dishwasher cavity? Meaning that the allowed space should be 600mm + 2 end panels? Thanks in advance. Re: Infill/End panels 2Oct 19, 2009 3:50 pm - Is there a standard width for these panels or does it depend on the cabinet manufacturer? Yep usually 16mm - Should infill/end panels be used in the following.. - If the overhead cupboards change in height? (i.e. a microwave cabinet will hang lower than a standard cupboard it is next to) Yes, but depends on the box check with supplier i have seen them made using the door colour which may negate this. - When using an underbench oven cabinet, should the infill panels be on either side? I have done it with out them in the past - On either side of the dishwasher cavity? Meaning that the allowed space should be 600mm + 2 end panels? Yep unless its integrated/semi integrated. Re: Infill/End panels 3Oct 19, 2009 9:13 pm If your finish is melamine or 2pack painted panel width is 16mm - if the finish is a vinyl skin then width is 18mm These panels can also provide the heat shield next to the oven. And I think they add to the appearance if used either side of the dishwasher, and also if they are either side of the fridge. cheers yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5243 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2133 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3852 |
