Browse Forums Kitchen Corner 1 Oct 02, 2009 12:21 pm Hi all, I received a built in dishwasher as a wedding pressy, and I need to build a cabinet for it at the end of my kitchen run. I have ordered two end panels (flat pack-they extend to the floor), which I intend to brace to the floor with L brackets (can't attatch to the wall - asbestos ). My question is about the benchtop. The rest of my kitchen is "granite" laminate, and I was thinking about using a piece of actual granite I have ****** around (I like granite as it can be used for pastry and as a chopping surface). As this piece is not quite large enough it would need to be supported by and surrounded with timber. Do you think this will look like a ******* add on? The other thought I had was to get hold of a timber chopping block slab and use that. Where would I get this? I am pretty poor so cost is an issue. Any ideas? I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2697 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4699 |
