Browse Forums Kitchen Corner 1 Sep 28, 2009 11:05 pm Hi does anyone know if you can put power points in essa stone,? We are thinking of using it as a splashback and I have not seen any with power points in it My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: Essa Stone 2Sep 29, 2009 6:04 am If you can cut a hole in it (which you can) you can put a GPO in it. Just FYI, as pointed out in another recent thread, reconstituted stone tops (which Essa stone is) can not be used behind cooktops as they are not technically fire retardant. If this is an issue the area will require another material or a design where the splashback is more than 200mm away from the cooktop. Cheers, Earl Re: Essa Stone 3Sep 29, 2009 9:08 am Thanks Earl. So I gather it is just treated like a big very thick tile when putting a power point in it We are going to put stainless steel behind the hotplate. My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: Essa Stone 5Sep 30, 2009 4:09 pm Thats good to hear, did it cost any more than putting in a normal tile do you know? My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: Essa Stone 7Sep 30, 2009 4:27 pm Thanks again that sounds good My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7414 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5611 |
