Browse Forums Kitchen Corner Re: Lights for kitchen work area 21Feb 07, 2008 1:08 pm Led's tend not to give as much light as the pic above - but it is ideal as under cupboard lighting - the voltage is low as is the need to hide wires fitting etc in a false sections etc may not be required.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Colours are getting better and away from the stark white look - and just be careful re costs - this is newe technology and some vendors seem to be charging worse than a wounded bull. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lights for kitchen work area 25Feb 07, 2008 2:56 pm ewan,
start chasing my friend..... i do wish you would stop doing that Re: Lights for kitchen work area 28Feb 07, 2008 3:22 pm ewan Length = 600mm Width = 70mm Height = 25mm 3X20 WATT 12V let me know if u're interested and i'll chase up a price. Tad too long for the cupboard to the left of the rangehood, it's only 550 and the pantry is right next to it. Kitchen lights 30May 03, 2008 12:00 pm Hi there,
Do you have a provision for a recessed light to be fitted, or must it only be a surface mounted light like the ones Ewan has mentioned? Let us know if you require any other thoughts on this topic, as the thread is a little dated. Re: Kitchen lights 31May 03, 2008 1:24 pm MICA Hi there, Do you have a provision for a recessed light to be fitted, or must it only be a surface mounted light like the ones Ewan has mentioned? Let us know if you require any other thoughts on this topic, as the thread is a little dated. Yes please Mica! Any thing on led lighting for cabinets, wardrobes etc. Thread may be old but new people are always building and technology changing. Mrs B CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23024 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 |
