Browse Forums Kitchen Corner Re: Lights for kitchen work area 7Jun 09, 2007 8:05 pm Hi mek,
I have done this many times with projects; the most efficient lighting for this use is what I call STRIPP LIGHTING. Small fluorescent lights attached to the bottom of the overhead cupboards. This is the best form of task lighting in my opinion. You can put them on a dimmer, so they can also be used as mood lighting at night. Lights such as down light and Low Halogens are directional lighting; they shine DOWN only, and do not cover the full surface, therefore not as safe. You need to be careful of lighting that throws another colour other than white, as it is can be harsh for the eyes. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Lights for kitchen work area 8Jun 09, 2007 8:11 pm Florescent is harsh on my eyes.
I much prefer the light from Low Voltage DL's. I am also not a big fan of "white" light. I prefer the incandescant golden effect as opposed to the clinical white of the energy savers... Matt Re: Lights for kitchen work area 9Jun 09, 2007 8:13 pm But when it comes to task light Matt, you need a crisp light. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Lights for kitchen work area 10Jun 09, 2007 8:15 pm Michelle,
We have gone for the same lights setup (and general style) as this pic: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have 3 LVDL's above the workbench, 4 LVDL's in the bottoms of the overhead cupboards and 2 LVDL's in the ceiling. I have them on 3 seperate switches (1 plate) for each area being used. Re: Lights for kitchen work area 11Jun 09, 2007 8:17 pm That said though I don't spend much time in the kitchen (i burn water!!) so I don't claim any expertise in task lighting at all! Re: Lights for kitchen work area 12Jun 09, 2007 8:27 pm They look great good, while they are all turned on at once.
But turn off the over heads on the island bench and what do you have? A few directional lights on the back wall, still not throwing an even light. I also think they are too obvious for under cupboard lighting. Just my opinion of course. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Lights for kitchen work area 13Jun 09, 2007 8:34 pm Michelle Just my opinion of course. Yeah! And what would you know?? Point taken though.....hmmm Re: Lights for kitchen work area 14Jun 09, 2007 8:39 pm Matt, take a look at how they throw off from the tiles…..reflection I mean.
Now scroll your photo up so you cut off the overhead lights over the island bench and can only see the back wall…….what do you see? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Stripp Lighting 15Jun 09, 2007 8:53 pm Michelle,
I hope you don't me asking but I love fluros (changing my whole house to them practically). I saw you mention STRIPP lighting and very interested for my kitchen. I was planning to have fluro lights anyway. My only problem is that I am not having any overhead cupboards. It is an island kitchen so the island will be under a fluro. On the wall based cabinets there could still be shadowing from the appliance cupboards and oven cabinet, rangehood etc. Is there anything I could use above the glass splashback to put light directly on the bench or should I just use ceiling fluros. Jola Re: Lights for kitchen work area 16Jun 09, 2007 9:02 pm (((My only problem is that I am not having any overhead cupboards.)))
I’m confused??? (((On the wall based cabinets there could still be shadowing from the appliance cupboards and oven cabinet, rangehood etc.)))) I thought you said you weren’t having overhead cupboards?? You will still get lighting from your rang hood for the stove top. NOW is there cupboards above the glass plash backs? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Lighting 17Jun 09, 2007 9:22 pm Sorry should have been more specific.
To one side of the benchtop will be a high oven cabinet. There will be a rangehood above the glass splashback after 60-80cm of benchtop. There will then be no overhead cupboards for about 100-160cm. At the other end of the bench will be rollfront appliance cabinets but these are sitting on top of the bench so are practically a wall at the end. Cheers Re: Lights for kitchen work area 18Jun 09, 2007 9:30 pm OK……so if I have got this right, you should have no interrupted lighting from your ceiling to your bench top, expect for the rang hood?
You should be ok, as long as you remember to put fluro lights above the work surface on the ceiling. I think putting lighting up on its own above the glass splash backs could look a bit tacky. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Lights for kitchen work area 19Jun 10, 2007 10:21 pm Thanks, everybody. The links are great although I would suspect not of the cheapest things available.
After reading about fluorescent vs iridescent type of lighting, I've decided to go fluorescent, I found this useful: http://www.greenhouse.gov.au/yourhome/t ... l/fs45.htm You're right again, Michelle ! Re: Lights for kitchen work area 20Feb 07, 2008 11:38 am Sorry to bring this old post back up, but I can't decide what lighting to use. The flourescent lighting that Michelle has mention, seems like a good idea but can't figure out how they would look. Are they simply surface mounted underneath the cupboards? Would it achieve a similar look to this (it's using leds)?
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ For downlights, how are they wired? Is a false floor created in the o/h cupboards to hide it? Here's a drawing of the overhead cupboards in question Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23024 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 |
