Browse Forums Kitchen Corner 1 Aug 27, 2009 11:11 pm Has anyone used the opti-space connector kit for Oliveri sinks. I could not find much information on them, I think they may cost about $80. Wondering if the extra $ would be worth any extra space gained under the sink cupboard as the pipes are supposed to take up less room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Opti-Space Connector Kit for Oliveri Sinks 3Aug 28, 2009 7:06 pm I will be going from a 900mm wide sink cabinet to a 600mm size, so I need all the space I can get. We shouldn't have any issues with where the pipe will go through the floor as we have a highset house with easy access in that area, if it has to be moved from where it is now. Along with dishwasher pipes, powerpoints etc, I would like as much shelf space as possible. I have seen kitchens without a shelf under sink, but I still want my shelf Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 21022 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10053 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3611 |
