Browse Forums Kitchen Corner 1 Aug 08, 2009 8:26 pm We're in the middle of the rough in stage and there has been a roughly 12mm metal pipe, its coated in plastic, and its running from where the oven might be out to the side of the house, just wondering what it might be? We are having a gas oven and cooktop, so maybe its going to be like a gas vent pipe or something? I thought it might have been related to hot water but the plumbing has now been done and the hot water is about 3 metres away from it. Any idea's?? Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Random Copper / Metal Pipe running from kitchen 2Aug 08, 2009 9:52 pm bill, Sounds like your gas supply line. If you are having LPG gas tanks it will attach to those outside the house. Ozz Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Random Copper / Metal Pipe running from kitchen 3Aug 08, 2009 10:18 pm I am having bottles yes, the houses ive seen running bottles have small little gas pipes running from the regulator into the house though, thought it would be similar Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Random Copper / Metal Pipe running from kitchen 4Aug 08, 2009 10:28 pm Our's is a large plastic covered copper pipe. Runs plastic all through the roof space then the copper is exposed once it's in the kitchen. Same for our gas line running to the fireplace. It's enclosed in a yellow enclosure. Probably for added safety inside roof spaces. We are having bottled also as there is no underground gas at Spring. Ozz Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Random Copper / Metal Pipe running from kitchen 5Aug 08, 2009 10:34 pm Well that must be what it is, thanks Shame natural gas isnt plumbed into a lot more places, its a lot cheaper and its uptake would be greater.. Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Random Copper / Metal Pipe running from kitchen 6Aug 08, 2009 10:48 pm yeah i would prefer natural aslo so we don't run out of lpg. here I will be in winter with fireplace going and then can't cook stir fry dinner as we are out of gas... Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Random Copper / Metal Pipe running from kitchen 7Aug 08, 2009 10:52 pm haha i would have preferred to have gas hot water but on bottles it costs a fortune Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5117 2 6198 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20193 |
