Browse Forums Kitchen Corner 1 Jul 28, 2009 2:59 pm We have had some problems with a chemical reaction of some sort on our benchtops so the builder is replacing the laminate only.(wont use the same brand) We currently have dark, 50mm square edge tops and where thinking of going light instead. Only problem is if we go light colour with a square edge will the joins be really noticable. Does anyone have closeups of this? I will post a pic as soon as I can. Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Re: Joins in light coloured laminate... does it annoy you? 2Jul 29, 2009 1:47 am There are some solid colour laminates that the colour goes right thru the laminate so the joint looks less obvious. Re: Joins in light coloured laminate... does it annoy you? 3Jul 29, 2009 1:31 pm Hey Kylie!!!! Long time no see...would be interested to see pics of the kitchen problem though has coral been good about fixing it? 2014 - Prepping to build the Soho 4 with Plantation homes, industrial style 2009 - Built the Brampton with Coral Homes viewtopic.php?f=31&t=15399&start=280 Re: Joins in light coloured laminate... does it annoy you? 4Jul 29, 2009 10:10 pm I asked a similar question just last night - someone mentioned a product called colorfill designed to hide the join and scratches. It is hard to find on the internet so I might ring laminex tomorrow. Otherwise, I know the joins will make me mental,so unless I can persuade the other (more budget conscious) half to go quantum quartz, I will probably go a mid colour -eg Laminex toffee stone or Kashmir Granite. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6328 We are doing heaps of hybrid at the moment and the cost sits between $60-65/sqm including installation. Stairs are around $90-100 each 1 4306 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4909 |
