Browse Forums Kitchen Corner Re: what is the best way to clean stone bench tops 21Aug 11, 2010 7:57 am Anyone have any ideas to clean stains out of caeser stone? Builder; Big M Design; Soho 32 Facade; Ascent Blog; http://mickeyb-soho.blogspot.com Trend; viewtopic.php?f=31&t=23990 Re: what is the best way to clean stone bench tops 22Aug 11, 2010 9:54 am On the weekend I laid some lilies on my caeser stone while I put water in a vase & when I picked them up, they had left a yellow stain (from the inside of the flower) I've only been back in our house a few weeks & thought I had stuffed it. First thing I grabbed was the white jiff bottle & worked it in - after a couple of minutes it finally went .... I won't be doing that again in a hurry:? What sort of stain is it?? Jazz Life is like a lolly, suck it and see Re: what is the best way to clean stone bench tops 23Aug 11, 2010 10:10 am Be gentle.. If you use too much abrasion you will be putting fine scratches in the surface and that is where the trouble starts. A bit like Stainless steel if you scratch it, it will never be the same. Ask you supplier if you can use a bleach to remove stains Where you are coming from is where you are going to... Re: what is the best way to clean stone bench tops 25May 03, 2015 9:02 am Having three avid toddler graffiti artists, I can highly recommend Orange Power "lime and orange oil". It is particularly effective on biro. I can't speak for its effect on the caesar stone itself - mine does not appear to have suffered but i do wipe it off within about 30 seconds of its application. You can buy it in Coles (orangepower.com.au). You won't look back. I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 1528 4 9070 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4548 |
