Browse Forums Kitchen Corner 1 Jul 20, 2009 11:13 am Hi all, I see that new homes have fridges placed inside a cavity. We're going to do the same thing but we're quite concerned about the depth of the fridge space. The width of the cavity will be 1000mm and the height is about 1800mm, yet the depth is a big problem. Looking at the image shown below, you could see that the total depth of the cupboards ~600mm, so we'll be limited to a 600mm deep fridge. We were at HN on Saturday night and noticed that many fridges are ~800mm deep, so if we want to go with one of these fridges, we'll end up with 20cm popping out of the cavity. What do you think of these 800mm and has anyone of you modified their plans to fit these 800mm deep fridges ? Cheers Re: Depth of your fridge space ! 2Jul 20, 2009 11:18 am I think my fridge hangs out by about 12cm but you need this because otherwise the fridge door will only open to 90 degrees (which would be a pain when you want to pull the shelves out to clean it) Building 'The Kingston' (with 'Boston' elevation) through Blueprint Homes in Hocking, Perth **PCI complete 06.02.10** My Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=17607 Re: Depth of your fridge space ! 3Jul 20, 2009 11:32 am OUr fridge would have stuck out about 170mm if we hadn't have increased the depth. We ended up turning the mucked-up space in the study into a wardrobe. It's easier to just show you the plan http://4.bp.blogspot.com/_-8RZB4dOY5I/S ... ified1.JPG Building a Modified Lawson Modern 29 @ Botanic Ridge, Cranbourne South, Victoria Re: Depth of your fridge space ! 4Jul 20, 2009 11:48 am UNfortunately I don't think you'll be finding a full size 600mm deep fridge anytime soon. Incorporating a fridge into the kitchen design means one of three things: 1. The panel that divides the fridge and the bench will be 150-200mm wider than the benchtop (this would be the most common way in a standard kitchen). 2. The fridge is set back into the room behind to allow it to finish flush with the 600mm bench. 3. THe 600mm bench is bought forward to allow it to finish flush with the fridge (therefore creating a 200mm void behind the bench/cupboards) Blog is now up - http://www.jbdave.blogspot.com/ Re: Depth of your fridge space ! 5Jul 20, 2009 11:57 am We have 800 on our plan. So I think it might still stick out but just the doors. Still have to buy a new fridge so will see once we buy it. Forum thread viewtopic.php?f=31&t=22300 Re: Depth of your fridge space ! 6Jul 20, 2009 12:15 pm Well mine sticks out too far and I am totally peeed off DH needs to get a flat plug which will help a bit, if I had know I would have increased the depth of the cupboards or used the exterior wall in some way. It's good you realise this now. Re: Depth of your fridge space ! 7Jul 20, 2009 12:29 pm These are our Fridge measurements: Height: 1760mm Width: 900mm Depth: 810mm Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Depth of your fridge space ! 8Jul 20, 2009 1:14 pm My fridge depth is 830mm - just enough i think 2014 - Prepping to build the Soho 4 with Plantation homes, industrial style 2009 - Built the Brampton with Coral Homes viewtopic.php?f=31&t=15399&start=280 Re: Depth of your fridge space ! 9Jul 20, 2009 2:14 pm aaaah it's amazing the things you have to pick up on!!!! my builder has given us 600mm depth for the fridge, nowhere near enough - just checked the depth of our new fridge (which we're not using until we move in) and it's nearly 800mm ugh Re: Depth of your fridge space ! 10Jul 20, 2009 2:20 pm Thanks for your replies guys. I think we'll end up buying one of these 630mm deep fridges. 800mm sounds good, but they'll look ugly If I ask my builder to increase the depth into 800mm he'll charge me an arm and leg, but he'll have to kill me first Re: Depth of your fridge space ! 11Jul 20, 2009 6:21 pm Ours is 1000mm But that was only because our kitchen has lots of angles and that was just the way it worked out - we wanted a larger than normal space and I guess we got that! hehe I am not a huge fan of seeing fridges sticking out heaps especially in walkways, if you have the choice get the depth, that way you can have it as far in or sticking out as much as you like ICK So glad the building is over, never again. Loooove our house, but still not quite sure it was worth all of the stress they put us through! Re: Depth of your fridge space ! 12Jul 20, 2009 6:41 pm If you have a look around, all the fridges stick out a bit. I dont personally like it. My fridge space is way to big its 1.4mx1.2m. I thought about reducing the depth and have a desk in the bedroom behind, but I prefered that wall to be straight. Re: Depth of your fridge space ! 13Jul 20, 2009 8:07 pm Its alright if the fridge sticks out a little, dont be too worried Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Depth of your fridge space ! 14Jul 20, 2009 10:17 pm I think from memory ours had to be 880 deep - but this was also to allow for air movement as well. But we are having the fridge integrated so the walls around had to be constructed to the exact measurements on the F&P website. Some things are worth waiting for. Re: Depth of your fridge space ! 15Jul 20, 2009 10:28 pm I made a last minute modification when building the frame to allow the fridge to sit flush. Behind it is a linen cupboard so we have lost a bit of cupboard depth but its worth it for what it gains on the other side. The depth of the fridge recess is now 850mm and width 1000mm. Re: Depth of your fridge space ! 16Jul 20, 2009 10:51 pm Most fridges I see stick out, unless they are integrated... Re: Depth of your fridge space ! 17Jul 20, 2009 11:05 pm Ohhhh... I didn't want to read this!!! My fridge depth is about 600-650mm. *Built with Gemmill Homes in WA* Slab - 1st June 2009 Plate Height - 17th June 2009 Lock Up - 18th August 2009 PCI - 5th October 2009 Hand Over - 15th Oct 2009 https://forum.homeone.com.au/viewtopic.php?f=31&t=20844 Re: Depth of your fridge space ! 18Jul 21, 2009 7:23 pm My builder has included a 825mm deep wall on the right hand side of the fridge space. The left hand side is the bench end which looks to be 600mm deep. Seems to be the same approach for my previous house as well. Re: Depth of your fridge space ! 19Jul 21, 2009 7:48 pm AAAhhhhhhhhhhhh! I just checked our plans and it's 650 depth. OMG! After sitting there and discussing with the bloomin kitchen lady if the cavity will suffice, I do believe that she only considered the width and height. The fridge that we were GOING to get is 84.2 deep. OH geez. Oh well have to get the other one I suppose. I am so glad that you bought this up italk, I think, now I am furious www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27467 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5547 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 8923 |
